Tractor Talk Discussion Forum
tractor lights
jason eddleston
01-14-2008 16:30:52
i have a 1937 ustyled b,can i put light on it,can i run it of the mag??or is there anther way,thank you..
Indiana Boy
01-15-2008 06:16:31
 Re: tractor lights in reply to jason eddleston, 01-14-2008 16:30:52
I think, but am not positive, that your fan shaft should have a pulley to run a generator. I know for a fact that the 37 unstyled A's did and think that the B's did also. Deere offered a lighting option and a generator was run by the pulley. It would be fairly easy to make a bracket to hold a generator or alternator. You could then have all the lights you wanted.
jason eddleston
01-15-2008 10:02:42
 Re: tractor lights in reply to Indiana Boy, 01-15-2008 06:16:31
i can put lights off just a generator?i dont need a battery?i know they had a light kit at one time for UNSTYLED A,B,G,DOES ANY ONE REPRODUCT THAT OPTION?THANK YOU..
Janicholson
01-14-2008 16:55:45
The lights on a small snow blower work from a permanent magnet alternator in the flywheel. Near the mag, or built in. Another way to light your efforts is to use a 12V battery and make a place to locate it while using the tractor. Then charge it between uses. A 70 amp hour battery will keep lights going for 2 to 3 hours. JimN
gene bender
01-14-2008 16:42:01
The mag wont lite anything outside of a spark plug. If you want lites you will need a generator and a battery.
jason eddleston
01-14-2008 16:49:30
 Re: tractor lights in reply to gene bender, 01-14-2008 16:42:01
ok,im just wondering how the light works on a snow blower that has no battery,gen??
gene bender
01-14-2008 21:32:50
 Re: tractor lights in reply to jason eddleston, 01-14-2008 16:49:30
there are magnets in the flywheel and a core on the block and if you notice the faster the engine runs the briter the lite and also look at the speed of the flywheel.
buickanddeere
01-14-2008 17:17:26
There are additional separate generator windings that are spaced around the spinning flywheel. Different additional magnets from the ignition system are added onto the flywheel as well.
