Tractor Talk Discussion Forum
R1 or R4
Vacherie
01-14-2008 19:28:40
Which last longer?
What are replacement costs for each?
I am interested in 24" tires for an Kubota 30 hp.
buickanddeere
01-15-2008 19:36:38
 Re: R1 or R4 in reply to Vacherie, 01-14-2008 19:28:40
Grass, gravel or pavement? Loader work, field tillage or lawn mowing?
Vacherie
01-15-2008 21:12:35
 Re: R1 or R4 in reply to buickanddeere, 01-15-2008 19:36:38
Mostly pasture cutting. I would like an estimate of replacement costs also.
buickanddeere
01-16-2008 19:25:12
 Re: R1 or R4 in reply to Vacherie, 01-15-2008 21:12:35
Link
Lumpy
01-15-2008 18:50:31
I had a Kubota L3300 GST that had the R4's on it. They seemed to have some advantage over the R1 when backing up. Definately better flotation. As far as wear, I can't answer that one. Mine were 14.9x24's rear and 10.00x16.5 on the front.
DiyDave
01-15-2008 16:21:22
Rob- is that a Kubota Thing, having to change rims? As far as I know, R1 and R4 still will have the same diameter, as long as the rim diameter is the same. The only thing I know for certain is that R1's give better traction in muddy field conditions.
gene bender
01-14-2008 21:46:29
Depending on your rims width you can get some new 8.3x24 delivered for 125 ea they are 6ply and last a long long time with reasonable care not setting in hot sun ect.
RobMD
01-14-2008 20:28:29
what are you using it for? What is on the tractor now? Keep in mind that the rims are not interchangeable between r1 and r4 tires.
SO in effect, if you had a tractor that currently has r1 tires on it, then, you have to use r1 tires on those rims.
Vacherie
01-14-2008 20:54:09
 Re: R1 or R4 in reply to RobMD, 01-14-2008 20:28:29
Looking at a new Kubota L2800 to be used for miscellaneous work.
