Tractor Talk Discussion Forum
OLD Seen your tractor you got.
Larry59
01-15-2008 20:16:27
Seen your Case in the photo section. Look pretty good from the rear there. Also seen that eagle hook on 3 pt setup. .. Still down with this dang head cold. ...My tractor is setting for a few days no matter what. Top radiator hose gave up the ghost and green stuff is everywhere! Could not find one at auto parts here. Even went to Eldon Napa and no luck. Had to order it and won't be in till friday or saturday.... Did find no thermostate in engine. So guess I will get one of them tomorrow...Now wondering if that radiator might be half stopped up. .. It was like it built up a back pressure and popped the hose open.
CENTAUR
01-15-2008 22:12:50
 Re: OLD Seen your tractor you got. in reply to Larry59, 01-15-2008 20:16:27
I hope your RADIATOR CAP Seal has not expanded and made it impossable for the cap to let off excess pressure when it heats up. CAPS are often the problem.The seal can be trimed off with a scissors if it has enlarged,till you can get a new one. CENTAUR
Larry59
01-16-2008 16:36:30
 radiator cap in reply to CENTAUR, 01-15-2008 22:12:50
I took the radiator out and found it not to be stoped up. So have ordered a new cap that is just for my tractor. The tractor place gave me one they thought would be ok... had to order the top radiator hose to and it will be in Friday or Saturday. But found my tractor had no thermostat in it so it to was ordered. .. now got to buy all that anti freeze. Oh Well... thanks
