Tractor Talk Discussion Forum
OT: Need Help to Identify Rims
El Toro
01-19-2008 04:23:23
A retired policeman in SC needs help to identify these rims he found. They look to be from a 1934 Ford. Hal
third party image
third party image
Mike in Ohio
01-19-2008 09:48:24
 Re: OT: Need Help to Identify Rims in reply to El Toro, 01-19-2008 04:23:23
I have a pair that look exactly like those on a utility trailer that Grandpa built from a ford model B axle. The tires on them are 5.25/5.50 x 17". Coker tire has tires that size and also has replacement hub caps for those rims. Good luck, Mike
moonlite 37
01-19-2008 08:59:36
34 Ford my folks had after WW2 was 16 Inch rear and 17 Front. I would assume that during the war the owners used what they could get.
gene bender
01-19-2008 07:09:10
With the FORD V8 emblem on them sounds good to me.
El Toro
01-19-2008 07:08:35
Thanks to all of you that responded. I'm sure Bobby in SC will be pleased too. Hal
Duner Wi
01-19-2008 06:25:20
To the best of my knowledge that wheel was used in pass and comm from 1932 thru 1935. 1932 was 18"
33=34 was 17 inch
35 was 16 inch in wire spokes. 36 was steel disk with different bolt pattern. Kinaa looked like a early VW Beetle wheel. Wheels got moved around during the war due to tire shortage. Hope this helps.
coloken
01-19-2008 05:55:22
Like Bill... From My 1936 ford. Same wheel, same hub cap. I had saved the wheels and some body stole them.
Kenny
bradley martin
01-19-2008 05:23:58
Model A Ford???
El Toro
01-19-2008 05:31:05
 Re: OT: Need Help to Identify Rims in reply to bradley martin, 01-19-2008 05:23:58
That's what he thought they were. I'll let him know. Thanks, Hal
BillD1
01-19-2008 05:30:50
1932-1936 Ford 6.00 -16 size
