Tractor Talk Discussion Forum
1/2 npt pipe plug what size drill bit???????
BUDD
01-19-2008 06:37:16
I need to install a 1/2 npt pipe plug into cast aluminum. What size drill bit do I need to use?
Thanks for the help
BUDD
Tinker In TN
01-19-2008 15:15:55
 Re: 1/2 npt pipe plug what size drill bit??????? in reply to BUDD, 01-19-2008 06:37:16
If you want to be precise, the 23/32 would probably be the way to go. But, you CAN get by with a 3/8 drill bit. I've done it. 3/8 would be 24/32, which is only 1/32 of an inch larger. A pipe tap is tapered, which means that the tap gets larger as you screw it in the hole. So, you have to screw it in just a little deeper, when cutting the threads. So, the question is, how precise does this have to be?
teddy52food
01-19-2008 10:29:37
If you have a female fitting use a bit that just goes in. Try it in a thin piece of scrap iron first.
Vito
01-19-2008 10:18:46
The size is 45/64 as the gentleman already stated.
Vito
gene bender
01-19-2008 08:29:29
Be sure to use a tool to taper the start of the hole to get threads straight and it sure will help starting the tap. I have a 60deg tool in the drill press does great.
ScottyHOMEy
01-19-2008 10:04:47
 Re: 1/2 npt pipe plug what size drill bit??????? in reply to gene bender, 01-19-2008 08:29:29
I can think of a couple times that trick would have saved me a headache or two!
Thanks, Gene.
El Toro
01-19-2008 07:41:44
If you're needing to know the tap drill size for 1/2'pipe is 23/32 that's been suggested. Hal
ScottyHOMEy
01-19-2008 07:37:53
23/32"
Here's a link
671DKS
01-19-2008 07:19:28
well for 1/2-14 the size would be a 45/64 drill or size .703 as you are using dissimilar metals make sure you use some anti-sieze on those threads as well. will help in dissasembly later on if needed.
671DKS
01-19-2008 07:24:18
 Re: 1/2 npt pipe plug what size drill bit??????? in reply to 671DKS, 01-19-2008 07:19:28
checked another site and it said use the 23/32 I don't know that it would matter much as you have a plus or minus with a gauge because of the taper. in other wise it depends on how deep you tap it. deeper makes the threads bigger the more shallow you tap makes a smaller hole.
El Toro
01-19-2008 06:54:18
The outside diameter of a 1/2" pipe plug is .840"
a 7/8 drill will be.875" in diameter. There's probably fractional drills that will be closer to the .840". Hal
Eric in IL
01-19-2008 06:46:32
23/32
