Tractor Talk Discussion Forum
owatonna 95 grinder
quiethunter
01-22-2008 11:43:35
i am looking for a mixer drive shaft for a owatonna 95 grinder mixer if someone could give me someplace to contact about parts i would apperciate it
JMS/.MN
01-22-2008 17:54:18
 Re: owatonna 95 grinder in reply to quiethunter, 01-22-2008 11:43:35
If you have the old one- take it to a machine shop and have another made. Should be mild steel, maybe a keyway at each end to cut in. Parts like that are not hardened.
Wayne from Wi
01-22-2008 16:47:27
I think Owatonna mills are Artsway mills. I might be wrong, but it might be available from them. Is it something that can be made locally. It would probably be cheaper.
Iowa corn and hogs
01-22-2008 13:29:26
Had one for years along time ago. Still have the parts manual, I'm sure. Just exactly what do you need? The PTO shaft? That would be easy--any good parts place could match that up.
Let me know if I can be of anymore help. I spent half of my life changing gears and bearings on the unloading system. A very happy day when I went to a hyd drive mill. Really a solid old grinder otherwise.
quiethunter
01-22-2008 14:07:15
 Re: owatonna 95 grinder in reply to Iowa corn and hogs, 01-22-2008 13:29:26
i am looking for the mixer drive shaft its the shaft that runs from the front drive to the mixer tank
