Tractor Talk Discussion Forum
Battery question
old
01-22-2008 15:34:32
Well I went to start my sons 1951 Chev and found the battery dead as a door nail. I hooked it up to a charger and figured I better check the water. Well its froze. So its there any hope that after it charges that it will be a good battery again or is it just a core now. I have never had a good battery freeze but know it can if the get drained like this one. So is there any hope??
Thanks.
Oh by the way I did drive his truck around a little and parked it where he will see it every day so maybe he will get it in gear and start working on it. LOL
guido
01-26-2008 11:56:41
 Re: Battery question in reply to old, 01-22-2008 15:34:32
HEY OLD
I agree with the other post slow charge first 12/24 HRS. 2 amps.Then normal charge if shows any sign of life. I think it is probably junk, Checking state of charge/capacity reguires load testing a fully charged battery at 1/2 the rated amps. for 15 seconds and it has to hold a minimum voltage of 9.6V at 80 degrees F. at the end of test. Then you 'll know for sure the battery is serviceable.
Guido.
Sam#3
01-23-2008 05:39:49
Be careful where you place it to thaw. The case may be cracked and although the electrolyte may freeze it’s still acid. It can make a real mess if it gets on any metal.
Dave (Tx)
01-22-2008 17:16:34
Put a slow (2 amp) charge on the battery for 24 hours. After removing the charger let the battery sit for about an hour then make sure all the cells have adequate water. If they need water add distilled. Your battery will now be charged. The question however is will it HOLD the charge. To find that out go to your local Wal Mart and spend 99 cents on a hydrometer. They are back in the battery section. Now test every cell with the hydrometer. If any of the cells are "dead" your battery is pretty well shot - dump it and get a new one. If at least 3 balls are suspended in the hydrometer for each cell then your battery will probably be alright.
Allan In NE
01-22-2008 16:09:38
Put it on a slow charge for at least 2 hours and see how it acts after it comes up.
Might be plumb okay....might be junk.
Allan
Janicholson
01-22-2008 15:50:11
Freezing can ruin the grids that support the lead. If broken, it may be toast. Thaw it and charge it. 50 50 chance. JimN
Walt Davies
01-22-2008 15:44:39
if its cold enough to freeze the battery then I sure wouldn't expect that kid to be out working on the truck.
If its completely discharged then the water is just that water and would freeze I would try to warm it and then charge it but I don't expect it will ever work again.
Walt
dave guest
01-22-2008 16:41:30
 Re: Battery question in reply to Walt Davies, 01-22-2008 15:44:39
Thank God for any kid who will work on anything. Future mechanic, electrician, craftsman, toolmaker, engineer, trucker, pilot, plumber,doctor,nurse, farmer, technician.....Make small investment now or large investment later. Many people my age are supporting kids for life.
old
01-22-2008 16:05:47
I would expect him to work on it either unless he fried up the wood stove which he can do any time he wants to. Its been in the shop now for a month so I had to drive it out so I can work on a couple tractors I have. Sure wish I had built the shop bigger so I had room for more then one project at a time. Either that or had some place to the tools that take up about 50% of the shop
Larry59
01-22-2008 18:32:39
 Cough' cough LOL in reply to old, 01-22-2008 16:05:47
Now Rich.. what did I just tell you about a building you need. Sale one of them many tractors you have and put up a nice one. LOL lol Hay going to look at a 3 axle trailer tomorrow morning. He is interested in my John Deere A , tractor. Might do a bit of bartering.
Sold my chickens so I can't trade them. lol
old
01-22-2008 19:25:51
 Re: Cough' cough LOL in reply to Larry59, 01-22-2008 18:32:39
Well I was trying to cal you to see if you wanted to go with me tomorrow to get that WC but I guess not
Larry59
01-23-2008 05:15:14
 OLDalready had plans. in reply to old, 01-22-2008 19:25:51
Well itis morning here and 7:16 am Wednesday. Here in mid Missouri. Bit cool outside and coffee is making. Have a dang headache again this morning. Had it yesterday to for sometime. ... Oh well got that appointment so I will head out for it in hour or so.
Thanks for the call last night. With the sickness I did not think of checking for two axles having brakes and not one on trailer like that. I picked up some valuable information on here today about my 97 Dodge and vacum lines. *S
Well call you later and let you know what happen
on the john deere A and the trailer deal.
