Tractor Talk Discussion Forum
cultivating corn with a couple of classics
billonthefarm
01-22-2008 22:29:07
I almost forgot about this video. Friends with camera's, aint they great! This was last year cultivating corn, or plowing corn as most of the old timers around here called it. bill Audio/Video clip:Untitled Audio Video
2t2@ia
01-23-2008 09:48:48
 Re: cultivating corn with a couple of classics in reply to billonthefarm, 01-22-2008 22:29:07
Thanks for the video. It brings back old times for me, too. I started when I was about 14 one summer when Dad had back trouble. We had a 1939 JD B. No power lift, but JD did have what I consider to be the best hand lift arrangement. Springs on each gang, an over center spring on the master lever, and you just hit the lever top to unlock the lever. It was still a lot to do at the end of the field.
Big M
01-23-2008 05:33:47
Thanks for the memorys, played it through twice. Spent many of hours on a JD 60 with a two row and no umbrella or radio, just a water jug. Get to the end and stand on the brake and turn around and go back on the same row you just came down on.
gene bender
01-23-2008 02:11:58
I get to plow several patches of sweet corn each summer with either the B with pneumatic lift and of course the umbrella. Some times i use the A set for two 30in rows with same set-up. The B FARMALL will do two 30in rows by using the offset shanks on the inside.
Fawteen
01-23-2008 01:13:58
Hoo, boy THAT brings back some memories!
Seems like I spent half my teen years on a '49 JD-B with a 4 row mounted cultivator. First time over at half-throttle in 2nd gear with shields may be the most boring thing I've ever done on a tractor.
super99
01-23-2008 01:29:38
 Re: cultivating corn with a couple of classics in reply to Fawteen, 01-23-2008 01:13:58
You bet! Hard to stay awake doing that on a hot day. BTDT. Chris
Texasmark
01-22-2008 22:51:41
Nice bunch of pics in all three threads.
Wonder what it will cost to fertilize that field in the third thread this spring? I"m fixin to find out on mine.
Mark
