Tractor Talk Discussion Forum
massey255
Kytim
01-25-2008 09:50:38
I have a MasseyFerguson 255 that I bought awhile back. It has a hyd hookup on it. It has two handles on the hyd block that sets between my legs. One handle goes to the 2 rear hyd and the other has nothing hooked to it. The problem is that it complicated to use. I have to ask the original owner how to use it all the time. (should write it down) to make the 3 point lift work the one that has no hyd plugs has to be secured back. To make the rear hyd work it has to be in the middle then the 3 point won't work. I guess my question is is there any thing I can do to keep from changing this all the time? Thanks
135 Fan
01-25-2008 18:04:50
 Re: massey255 in reply to Kytim, 01-25-2008 09:50:38
If it's the same as my 135, it's only complicated until you realize how it works. One lever makes the 3 pt. controls (on the side of the seat) work and the other makes the remote hydraulics work. They can't be used at the same time. There is a lot of info in the archives on here. Unless you install a seperate pump for aux. hydraulics, you'll have to keep switching valves back and forth. Dave
