Tractor Talk Discussion Forum
Re: 98 monte carlo problems
El Toro
01-26-2008 15:05:02
It may need a a new fuel filter. You should measure the fuel pressure to what that is at high speed when it starts the sputtering. If the fuel pump is in the gas tank it may have dirt or rust blocking the pump inlet. Had that problem on a Chevy Citation. I dropped the tank and it was full of rust. I cleaned the tank and installed a new pump. My neighbor said I wouldn't change that pump and I said you're not pulling the tank
and doing all this work. Pump was around $50.00. Hal
