Tractor Talk Discussion Forum
Ford 7810
Cathal
01-28-2008 00:54:58
I'm having problems with the clutch of my 7810. When the pedel is fully pressed the clutch is still not clear of the flywheel and it's difficult to put the tractor into gear. I have fully extended the little clevis on the clutch rod. Anyway i could not make it any longer as i will not have any pedal free play if i was to. Is there anything else i can adjust, that for a given length of travel for the pedal, will result in a longer travel distance for the clutch lever?? Many thanks
Cathal
RodInNS
01-28-2008 11:28:46
 Re: Ford 7810 in reply to Cathal, 01-28-2008 00:54:58
I thought that the rod had to be shortened to bring free play back in line as the disk wears...
Assuming that free play is correct, split it and find the problem. It could be the pinch bolt in the clutch cross shaft, a bad pilot or release bearing, or mabey the clutch itself. Dig in and find out...
Rod
Cathal
01-29-2008 07:56:01
 Re: Ford 7810 in reply to RodInNS, 01-28-2008 11:28:46
I was hoping not to have to split her, i don't have the time + its a costly job. If i do split her i'll put in a new clutch as i don't intend splitting her any time soon afterwards....
Cathal
01-28-2008 00:57:40
 Ford 7810 - clutch adjustment problems in reply to Cathal, 01-28-2008 00:54:58
I'm not sure if its the tractors original clutch, is there any way to know??
Fordfarmer
01-28-2008 07:12:40
 Re: Ford 7810 - clutch adjustment problems in reply to Cathal, 01-28-2008 00:57:40
sounds like its time for a new clutch.
Cathal
01-29-2008 03:40:26
 Re: Ford 7810 - clutch adjustment problems in reply to Fordfarmer, 01-28-2008 07:12:40
I thought that the clutch would be slipping if it needed to be replaced??
