Tractor Talk Discussion Forum
Need to double check my thinking
old
01-28-2008 14:39:21
I'm wiring up an alternator on a 1941 Farmall B but since it has a mag there the problem of no ignition switch. So am I thinking right that I will have to wire up a switch to excite the alternator and then when ever the engine is shut down the switch needs to be turned off again. Am I right??
Thanks
By the way theres not going to be any lights etc so I can't rig it that way either. Its a delco alternator but not the normal 10si but one off a new car or truck
dave guest
01-28-2008 17:37:52
 Re: Need to double check my thinking in reply to old, 01-28-2008 14:39:21
Oil pressure switch is a great idea and the most stock appearing hookup I could think of. No need to mess with mag. Should already have grounding switch and single wire.
dave guest
01-28-2008 17:37:37
old
01-28-2008 18:12:45
 Re: Need to double check my thinking in reply to dave guest, 01-28-2008 17:37:37
If the mag was the switch type if would be easy but its the cable pull type so no wires to the mag other then spark plug wires
Bob
01-28-2008 17:26:32
Simple.
Use a 2-terminal normally open oil pressure switch that closes at low PSI... the ones I use close @ 4 PSI. Standard Ignition brand, I can look up the part #, if you'd like.
old
01-28-2008 17:36:37
 Re: Need to double check my thinking in reply to Bob, 01-28-2008 17:26:32
Part number would be nice. I called the auto parts store tonight and they didn't even have a clue as to what I was asking for. But it was after 6pm here so they only let the dumb guys work that late.
Thanks
RodInNS
01-28-2008 21:00:38
 Re: Need to double check my thinking in reply to old, 01-28-2008 17:36:37
Old, it's a fuel pump switch you want. I think they are a 3 prong job. One grounds the oil pressure light and the other two spades are for the fuel pump. No pressure/no pump. You just wire the control for the alt through that switch. I forget the number of the one I used, but it's a pretty generic switch...
Rod
redjock
01-28-2008 17:06:46
Just finished working on IHTD-9 with 12 volt system. Needed a voltage regulator, took it to gen shop and he mounted a cutout on the generator.very simple and only needed to hookup bat wire to the cutout.I asked him about using altenator and if I needed to install a switch and he said if you use the later GM altenator all you need is the battery wire.
fixerupper
01-28-2008 16:40:00
Old,the early 1086 has an oil pressure activated switch that turns the digital tach on and off. Any dealer should have one. I don't know how it's rated for load capacity. Jim
onefarmer
01-28-2008 15:47:52
I'm with Duner. Add a pressure switch triggered by the oil pressure. That is how my MF265 and 175 both diesels are hooked up factory. The switch powers the fuel guage and the alt. With no batt ign to worry about seems the simplest way.
leroy in ne
01-28-2008 14:53:34
one possibility to think about, use double pole single throw switch, one side to mag and ground , other side to bat. and alt. that way you will kill engine and bat. power with one switch.
Duner Wi
01-28-2008 14:59:43
 Re: Need to double check my thinking in reply to leroy in ne, 01-28-2008 14:53:34
I believe another way would be to use an oil pressure switch teed in by the gauge.
old
01-28-2008 14:59:28
That would work if this mag had a shut off like that but its has the cable type shut off so that idea is out. I checked the mag today to see if it was set up only as a cable shut off or if it was set up for a switch or cable and its set up only for the cable
bhb
01-28-2008 15:06:08
 Re: Need to double check my thinking in reply to old, 01-28-2008 14:59:28
If I am reading this right, when the engine turns off the oil pressure drops and the oil pressure switch opens and disconects the alt.
Bill
Buzzman72
01-28-2008 16:03:55
 Re: Need to double check my thinking in reply to bhb, 01-28-2008 15:06:08
Actually, the average oil pressure switch [for a light] is OPEN when there is oil pressure--light is off--and CLOSES when there is no oil pressure, hence [oh-bla-dee, oh-bla-dah] the light goes on, warniing you of low/no oil pressure BECAUSE the circuit to ground is closed, not open.
Closed circuit = continuity, open circuit = no continuity.
steveormary
01-28-2008 17:02:13
 Re: Need to double check my thinking in reply to Buzzman72, 01-28-2008 16:03:55
old'
I did one with the double pole single throw switch like leroy in ne did. Worked fine for me however it was not on a mag.
steveormary
