Tractor Talk Discussion Forum
ford tractor
rick troxell
01-30-2008 15:22:39
my youngest son purchased what he says is a ford9n. it is a ford. It was used to cut along roads by Pa dept of transportation. It has duel wheels in the back. How do i find what model and year it is on the tractor so i can help him find parts. The engine has a slight miss and the bowl at the carb is leaking. It is also an automatic transmitiom. 10 forward and i belive 3 reverse.
ericlb
01-30-2008 20:51:28
 Re: ford tractor in reply to rick troxell, 01-30-2008 15:22:39
is there any way you can post a pic of the tractor? someone here will be able to id it if we can see it, then this site probably has parts for it
Jim.UT
01-30-2008 20:20:06
Try the link below.
Jerry/MT
01-30-2008 17:53:25
On the right hand side where the transmission case and the engine come together there is usually a flat spot where serial numbers and possibly model numbers are stamped. If they are still visible, they should help you ID this machine.
Lanse
01-30-2008 16:04:42
Either someone has too much free time and a junkyard or its not a 9N. The 9N has 3 foward and 1 reverse speed.
rick troxell
01-30-2008 16:34:19
 Re: ford tractor in reply to Lanse, 01-30-2008 16:04:42
thanks folks. I will apparently have alot to learn and so will the boy. will post in the ford forum after i get more info off the piece of equipment
Bob
01-30-2008 16:09:26
 Lanse... in reply to Lanse, 01-30-2008 16:04:42
You posted "The 9N has 3 foward and 1 reverse speed."
That IS true, UNLESS it has one of several aftermarket auxillary transmissions, Lanse, which are reasonably come on the old "N's", at least in some areas of the country.
But the "automatic" (powershift) thing DOES rule out the older tractors.
Lanse
01-30-2008 16:14:23
 Re: Lanse... in reply to Bob, 01-30-2008 16:09:26
I knew that LOL :-)
old timer in ohio
01-30-2008 15:38:11
Hey there rick;
Can't say i'm an expert on fords "N"series of tractors.BUT I can say i've never heard of an "automatic" transmission on any of em.
Bob
God Bless
Bob
01-30-2008 15:37:32
If it has powershift, it is AT LEAST 12 to 15 years NEWER than the last 9N.
That tranny is the "SOS"... Select-O-Speed, and it was available in a variety of number-series tractor models AFTER the 9N, 2N, 8N, and NAA.
Post on the "FORD" Board, and one of the gurus there can narrow it down more for you.
Andy Motteberg
01-30-2008 15:26:23
"How do i find what model and year it is on the tractor so i can help him find parts."
You said your youngest son says it is a model 9N.
Look on the left of any YT page and click on Serial Numbers to find out the year.
