Tractor Talk Discussion Forum
148 cid engine=how much HP
Larry59
01-31-2008 20:59:15
If the motor is a 148 cid engine in a case tractor. How much is the horse power??
old
02-01-2008 09:08:13
 Re: 148 cid engine=how much HP in reply to Larry59, 01-31-2008 20:59:15
My NEB. test list says the tractor is 30HP. So HP wise its smaller then that JD-A you had by about 10HP
Keith-OR
02-01-2008 09:40:20
 Ya But, in reply to old, 02-01-2008 09:08:13
Rich, it has costant running PTO, live hydrualics,Eagle hitch, and dual or triple range transmission...:>)..:>)
Keith & Shawn
old
02-01-2008 09:47:38
 Re: Ya But, in reply to Keith-OR, 02-01-2008 09:40:20
Oh I understand that is a plus big time. Plus most likely I'll end up turning a wrench or 2 on that tractor for Larry
Keith-OR
02-01-2008 11:28:42
 Re: Ya But, in reply to old, 02-01-2008 09:47:38
Yeppers, Larry has it all figured out.... Keep ya busy...LOL What I've been told by little burdie, "someone" needs ta keep you out of trouble...:>)..:>
Keith & Shawn(Special Olympic Champion)
old
02-01-2008 12:36:07
 Re: Ya But, in reply to Keith-OR, 02-01-2008 11:28:42
Trouble I never get into that. Plus since going to have that surgery done yesterday I'm sort of taking it easy for a few days Also since we have snow on the ground I'll stay in the house and play on the computer and watch TV till its core time
Triplerange
02-01-2008 05:13:21
Mike's right....about 30. Found in the 300 & 430 models.
Mike H. in TX
02-01-2008 00:00:13
This engine is in Case 430 and 440 tractors. The tractors are rated at 33 Hp gasoline powered. I have a Case 440 Utility with a loader. It works good.
jason, NW Ontario
02-01-2008 04:55:39
 Re: 148 cid engine=how much HP in reply to Mike H. in TX, 02-01-2008 00:00:13
Isn't the 148 also in the VA? That tractor model supposedly only has 17hp at the pto.
Gene Dotson
02-01-2008 06:11:54
 Re: 148 cid engine=how much HP in reply to jason, NW Ontario, 02-01-2008 04:55:39
No, the VAC used the 124 cu.in. engine... Gene
