Tractor Talk Discussion Forum
Voltage of starter
PeteM
02-01-2008 06:34:32
Trying to figure out what the voltage of the starter we have is. It came off a 1950 Huber maintainer with a hercules QXB5.
Janicholson
02-01-2008 06:39:18
 Re: Voltage of starter in reply to PeteM, 02-01-2008 06:34:32
90% chance it is 6volt.
But do not worry unles you intend to run it on 24 volts, it would be happy with 12 volts. The series wound starters found on old equipment only run one direction, and are not sensitive to doubling the volts. They will crank faster, and start the unit quicker, and be operated less as a result of the reduced time on task. I crank a 1957 CJ3B jeep starter with a 900 CCA 12volt. At 10 below it starte within 3 seconds of cranking. JimN
PeteM
02-01-2008 09:19:33
 Re: Voltage of starter in reply to Janicholson, 02-01-2008 06:39:18
We are putting the starter in our I-14 and would like it to run on 6 volts. A few modifications on our nose cone and it should work. thanks.
