Tractor Talk Discussion Forum
IH 434 Gas
Terry M.
02-01-2008 11:32:51
I have an IH 434 Gas tractor that won't start.
It turns over and catches but won't run. Gas pump pressure is good and I had the carburator rebuilt last year. It seems as if it is starving for fuel but I'm not knowledgeable enough to tell if the carb is really set up right. It ran after the rebuild but has been parked for a couple of months.
If anyone has an idea what the problem could be, I'd appreciate the input.
Terry M.
IH2444
02-01-2008 19:46:19
 Re: IH 434 Gas in reply to Terry M., 02-01-2008 11:32:51
I think your carb has a fuel shutoff solenoid on it, they are prone to go bad. Or it might not be getting voltage. And I also think the final fuel line elbow into the carb has a screen in it, could be plugged.
Not absolutely sure but my 444 has those.
hayray
02-01-2008 15:54:55
Check that electronic solenoid for the float valve.
GRub
02-01-2008 12:58:30
I would make sure the strainer in the fuel tank is clear and that you have steady stream of fuel downstream from the tank.
It may start on what in in the carb bowl but if it can't resupply the bowl it won't stay running.
Grub
Balatonm
02-01-2008 11:40:45
injectors possibly
Balatonm
02-01-2008 11:40:40
injectors possibly
