Tractor Talk Discussion Forum
4-wheel drive combination tractor
Mike Anderson
02-03-2008 14:43:24
I saw on RFDtv that someone had invented a device that combined two tractors with the front ends removed, they somehow had brackets and linkages to make the two tractors and combine them to make one four wheel drive tractor. I am not sure that I am describing this correctly but was really looking for a place where I can find pictures of this to show my father in law. I have tried doing a search on the internet but do not remember the name of the manufacturer.
Any help would be greatly appreciated.
Mike
Fordfarmer
02-04-2008 07:47:10
 Re: 4-wheel drive combination tractor in reply to Mike Anderson, 02-03-2008 14:43:24
There was at least one other company that had a similar set up. Might have been Ford, or sold through Ford, as the picture I have (I'll scan and post it, if I can find it) shows it set up with a 971 and a 6000.
richardinnz
02-03-2008 21:47:44
The manufacturer was Earnest Doe & sons, of Ulting, near Maldon, Essex, England. ( Just North of London) Called the Doe Dual Drive or Triple 'D', using Fordson Majors, the last were based on 2 Ford 5000 tractors and called the Doe 130. Doe's were Ford tractor dealers and as far as I know are still in business with New Holland as their main francise. The tractors make a lot of money, guide price for off farm in fair order is mid 50k and I am not talking Dollars!
JMS/.MN
02-03-2008 16:33:23
Then there is Dan Dufner, from Buxton, ND, who put 3 JD two-bangers together. I believe at least until recently he was doing his farm work with two units coupled together, with a Sound-Guard cab on the driver unit. Can find it in Farm Show archives.
JMS/.MN
02-03-2008 18:17:30
 Re: 4-wheel drive combination tractor in reply to JMS/.MN, 02-03-2008 16:33:23
google DON Dufner, buxton, ND, go down to the article about Steam Thresher Show at Rollag- it has a picture of his setup.
Frank in Florida
02-03-2008 16:16:34
There were commercial built tractors in england called the Doe Dual Drive based on ford tractors of the time. You can do a google search using "Doe Dual Drive" or "Doe Triple D". Frank
Tom in TN
02-03-2008 16:11:31
Mike,
That's fantastic! How do they steer that thing, and does it require two operators to sit on it at the same time?
Thanks,
Tom in TN
DiyDave
02-03-2008 15:32:17
John Deere finally gets a 4 cyl, and it aint even their design!
gene bender
02-03-2008 15:10:01
Back in the 60s there were tons of them done with all models used. Some even used and extra engine powered it thru the pto or belt pulley for extra power so theres no fixed way it was done. Just take off front spindle and fasten it to the drawbar and go.
Greg_Ky
02-03-2008 14:54:40
You mean like this?
third party image
Mike Anderson
02-03-2008 15:06:10
 Re: 4-wheel drive combination tractor in reply to Greg_Ky, 02-03-2008 14:54:40
Yes, that is it. What are those called. I have never seen anything like that. I watched a show on tv that had some JD's and IH's hooked just like that. But thanks so much for posting those pics. I can try to print them off and show my dad in law because he has never seen them either.
Mike
Greg_Ky
02-03-2008 14:58:45
Front view.
third party image
Greg_Ky
02-03-2008 15:06:38
 Re: 4-wheel drive combination tractor in reply to Greg_Ky, 02-03-2008 14:58:45
How about a video? Audio/Video clip:Tandem Tractor Video
Mike Anderson
02-03-2008 15:29:07
 Re: 4-wheel drive combination tractor in reply to Greg_Ky, 02-03-2008 15:06:38
Thanks a ton. That video was the same thing that I watched on RFDtv, I really appreciate all the help.
Mike
