Tractor Talk Discussion Forum
Glow plug question IH 424
v
02-07-2008 09:40:32
What is the easiest way to check glow plugs to find out which ones are good and which ones are bad on this tractor?
rrlund
02-07-2008 10:11:09
 Re: Glow plug question IH 424 in reply to v, 02-07-2008 09:40:32
Use a test light. Pull the wire off them. Hook the test light to the battery. Touch the light to the spade on the glowplug where the wire hooks on. If it lights,you have resistance and the plug is good. No light,no resistance and no good.
Bob
02-08-2008 14:00:40
 Re: Glow plug question IH 424 in reply to rrlund, 02-07-2008 10:11:09
It's NOT QUITE that simple. All 4 GP's are in series, and there are in effect two terminals on each GP.
NEITHER terminal is connected to ground.
You can use an Ohmmeter. It should show "infinite resistance" to ground from either of the concentric terminals, and VERY low resistance BETWEEN the terminals, if the heating element is intact.
Third Party Image
IH2444
02-07-2008 10:27:56
Yep that is the simplest way.
