Tractor Talk Discussion Forum
stuck engine oil
midlam
02-07-2008 10:17:12
anyone try this for stuck engines? a kroil copy?
enginerelease.com
billyar
02-08-2008 02:24:25
 Re: stuck engine oil in reply to midlam, 02-07-2008 10:17:12
.we used air pressure to free 330ih, removed the rocker arms and sparkplugs, put 120# of air on the front and rear cylinders rocked the back tires with the trans in high gear it turned 1/2 turn. Then moved the air 2,3 rocked again turned complete circle.
old
02-07-2008 11:29:43
The stuff might work but at that price you might as well take it apart and rebuild it. I'll stick with my cheap ATF and cross my fingers.
ramtuff
02-07-2008 15:11:02
 Re: stuck engine oil in reply to old, 02-07-2008 11:29:43
Amen to that Old.Like a down payment on new engine.
glennster
02-07-2008 14:01:12
and from the post earlier, mixing atf with acetone 50/50 was the super duper penetrating oil!!!!! i gotta mix up a batch and try it to see how it works.
Don-Wi
02-07-2008 11:44:35
You mean you don't wanna try it out on a 6 cyl. engine right away? It'd only cost $120+ S&H..... Hmmm.....
Donovan from Wisconsin
RustyFarmall
02-07-2008 11:12:13
$19.95 for 250 ml. By the time you bought enough of it to thoroughly treat a tractor engine you would have a good start on paying for a complete engine rebuild kit, which you are still going to need because even if the magic oil managed to do the job, you would still have pistons and sleeves that are severely pitted and beyond use. Just my opinion of snake oil.
Don-Wi
02-07-2008 10:40:18
Sounds like it's only good for very lightly stuck engines, so basically jus about any engine that the guys on here have would probably not qualify for "stuck during storage" like they claim.... Unless of course that storage is sitting outside for 30 years without a raincap...
JT
02-07-2008 10:49:13
 Re: stuck engine oil in reply to Don-Wi, 02-07-2008 10:40:18
Got A WD45 sitting out back that is stuck, it says it is guaranteed, I might have to order a couple "kits" and see if it works and if they will honor their warranty, this has been stuck for about 2 years.
Jim
supergrumpy
02-07-2008 11:03:35
 Re: stuck engine oil in reply to JT, 02-07-2008 10:49:13
2 years is not "stuck"
your engine is only a bit sluggish!!
JT
02-07-2008 14:52:39
 Re: stuck engine oil in reply to supergrumpy, 02-07-2008 11:03:35
Yep, gotta agree with you there. :>)
