Tractor Talk Discussion Forum
New Holland TC40A 1 or 2 Bottom Breaking Plow
Marvin Dickinso
02-09-2008 13:49:49
I have a New Holland TC40A 4X4, (40 Hp). I'm trying to figure out what size breaking plow I should get for it. Located some Ford and Dearborn 2 bottoms, and a few 1 bottoms. Mostly 14 and 16 inch. What should it be matched up with?
gene bender
02-10-2008 07:45:39
 Re: New Holland TC40A 1 or 2 Bottom Breaking Plow in reply to Marvin Dickinson, 02-09-2008 13:49:49
It isnt HP as much as weight, tire size, and does it have a three-pt that will adjust for a mounted plow. If you want to pull a trailer how wide is the rear spacing. Probably dont want more than 2 14s unless it weighs 5000lb.
Henry B
02-09-2008 17:13:31
I have a tc40 gear pull a john deere 3 14s trail plow in meduim to heavy soil with know problem
Don L C
02-09-2008 14:18:39
What type ground you have and how deep you want it plowed.....lets say its not hard clay.....and not sand....some where in the middle...40HP 4x4 should handle 4 14"s.....a little clay, I would say 3 16"s no prowlem....
Luke S
02-09-2008 14:24:32
 Re: New Holland TC40A 1 or 2 Bottom Breaking Plow in reply to Don L C, 02-09-2008 14:18:39
A TC40 it pretty light though. Is it a hydro or a gear trans? That'll make a lot of difference. Personally I think 2-12's will be a load on a TC40.
steveormary
02-09-2008 17:21:21
 Re: New Holland TC40A 1 or 2 Bottom Breaking Plow in reply to Luke S, 02-09-2008 14:24:32
You should pull 2-14's easy enuf,mabe 3-14's but no more.
steveormary
