Tractor Talk Discussion Forum
Mufflers
Mark W.
02-12-2008 06:47:33
Is there any harm in trimming three inches of a muffler?
DW in indy
02-12-2008 13:27:11
 Re: Mufflers in reply to Mark W., 02-12-2008 06:47:33
That's about what I trimed off my Farmall C. Used it 1 time and purchased another muffler. Couldn't take the fumes
Goose
02-12-2008 11:16:07
I once took out an overhead power line to a hay barn with an 856 Farmall. Six inches came off the pipe real quick.
willie in mn
02-12-2008 17:44:54
 Re: Mufflers in reply to Goose, 02-12-2008 11:16:07
That's gotta be one real tall Farmall. Code calls for minimum 15 foot clearance over road, driveway, parking lot, or any place where vehicle traffic can be expected.
WJ
Fordfarmer
02-12-2008 06:59:49
I assume you mean trim the pipe on one end or the other of the muffler... Nope, no harm, other thatn the exhaust will be that much lower, and closer to your face. I've done exactly what you're thinking about, to get the tractor through doorways that were'nt quite tall enough.
steve from mo - dangit!
02-12-2008 06:57:53
If you mean the outlet pipe that comes out of the muffler; no, except for the increased level of fumes in your face. You could have a removable extension pipe made up to remedy that. If you are going to cut out part of the body of the muffler that would be bad.
rrlund
02-12-2008 06:56:23
Nope.Would probably be a benefit to it if it keeps you from bending it going in the door of the shed.
