Tractor Talk Discussion Forum
Power Steering on 1967 I.H.
nosemostall
02-12-2008 10:53:21
The other day I noticed the steering did not seem normal. Ive had this tractor about six years a diesel engine and this is the first of any problems.
the problem is I can"t get the tractor to steer except but straight it has power steering or should I say had power steering. Does this series have a power steering pump of its own or does it run of the hydraulic fluid. if it has a power steering pump where will it be located.So what"s new always happens when it;s cold. Thank you (Ken from Elsberry, Mo
IH2444
02-12-2008 11:26:39
 Re: Power Steering on 1967 I.H. in reply to nosemostall, 02-12-2008 10:53:21
Yep the model would be helpful and also does it have hydraulic steering cyklinders under the front. Some models were equipped both waays and some have one hydraulic cyllinder and some have 2.
I suspect yours runs off the same pump as does the rear lift, does it work ?
Bob
02-12-2008 11:23:15
"Does this series have a power steering pump of its own or does it run of the hydraulic fluid"
It would help some if you'd give us a hint as to WHAT IH tractor you are working with!
nosemostall
02-12-2008 11:43:48
 Re: Power Steering on 1967 I.H. in reply to Bob, 02-12-2008 11:23:15
it is a 700 series I.H. with the power steering problems
Dave from MN
02-12-2008 11:52:04
 Re: Power Steering on 1967 I.H. in reply to nosemostall, 02-12-2008 11:43:48
is a a 1967 706?? That steering issue is common on cold 1963 through early seventies tractors. Just let her run a bit longer when it is real cold. I have the same issue on my 544 when it is below zero. Also check to make sure your hydraulic fluid level is full.
nosemostall
02-12-2008 13:53:10
 Re: Power Steering on 1967 I.H. in reply to Dave from MN, 02-12-2008 11:52:04
Dave thank to you and everyones concern. noo will you answer me this question. does the power steering have it's own seperate pump? kEN
Allan In NE
02-12-2008 14:04:34
 Re: Power Steering on 1967 I.H. in reply to nosemostall, 02-12-2008 13:53:10
What tractor is it? "700 series" sounds foreign?
Allan
Allan In NE
02-12-2008 11:26:44
Darnit Bob!
You're always so pickey! Wassamattau? :>)
Allan
Bob
02-12-2008 11:51:50
 Re: Power Steering on 1967 I.H. in reply to Allan In NE, 02-12-2008 11:26:44
Allan,
Don't you have a tractor you need to chain down???
Allan In NE
02-12-2008 12:01:47
 Re: Power Steering on 1967 I.H. in reply to Bob, 02-12-2008 11:51:50
ROFLMAO!!!!
