Tractor Talk Discussion Forum
JD 70 6volt system
George Boyer
02-12-2008 19:00:37
Im not sure how to get the coils to cut the six volts down to 2 for the pony motor.
buickanddeere
02-12-2008 20:18:56
 Re: JD 70 6volt system in reply to George Boyer, 02-12-2008 19:00:37
Ballast resistor. Coil voltage is closer to 5.0 volts however when running, full battery voltage while cranking. If you run the F.I.T. coil protection circuit. A ballast resistor is not required. 1-800-522-7448 for the electrical,power steering and service manuals.
