Tractor Talk Discussion Forum
165 front pump
ric1
02-13-2008 02:26:26
hello i have a mf-165 with a freeman 4000 loader on it it runs off the front pump (crankshaft) could anyone tell me what the gpm would most likely be for that pump without knowing what kind it is or should i get some numbers off of it first thanks RICK
ric1
02-13-2008 15:18:58
 Re: 165 front pump in reply to ric1, 02-13-2008 02:26:26
i contacted the local mf dealer and he says it is most likely around 19 gpm pump i need 13 gpm to operate a certain implement im looking into. thanks for your reply j. thanks RICK
J. Schwiebert
02-13-2008 06:05:44
Do you know the bore and stroke size of the lift cylinder.If you do or are close you can post that to us. Then run the engine a given RPM and time how long it takes for the cylinder to extend. We can then calculate pump flow. Also remember flow changes with RPM. 1200 RPM would be good as a lot of old hydraulic formulas are based on 1200 RPM. I also snr you an e-mail. J.
