Tractor Talk Discussion Forum
Draining JD B
mul-skiner
02-16-2008 15:47:55
How many plugs are there to drain the water on a 1950 JD B
john fff
02-16-2008 15:55:51
 Re: Draining JD B in reply to mul-skiner, 02-16-2008 15:47:55
There should be just one.
Leroy
02-18-2008 05:34:01
 Re: Draining JD B in reply to john fff, 02-16-2008 15:55:51
That is true if it is orignal without a water pump or if it has had the radiator bottom replaced with a factory radiator water pump from a 1952 tractor and it would be in the bottom of the head, a 1" diameter pipe plug. Dow the question is has it had an aftermarket warer pump added that sets outside of the raddiator and has a piece of radiator hose both in front and in back of the pump, if it has this then there has to be a drain in the bottom of that pump.
