Tractor Talk Discussion Forum
Re: Steel Prices
504-2
02-16-2008 19:52:04
The local Sheriff has two idiots in the can now the didn`t think anybody would mind if they helped them selves to the cooper in a local house that was empty.
RayP(MI)
02-17-2008 10:57:12
 Re: Steel Prices in reply to 504-2, 02-16-2008 19:52:04
We had a couple of guys picked up in the wee hours recently here with a truck load of stolen aluminum and wiring taken right off a center pivot irrigation system in a farmer's field.
Sam from WA
02-16-2008 22:29:46
now, i've got a question. this is legit, not illegal. we just tore down an old barn at my parents old place and pulled all the wiring so we could burn the wood the barn was built out of (it was full of powder post beetles). legally, we weren't even supposed to burn the wood, which is stupid, but burning it sure as heck beats haulin the whole 90x80 100 year old barn to the dump unburned. What is an easy way to strip the insulation off the old wiring so we can take it in for scrap copper? again, this is not an illegal activity, perfectly legitimate.
Larry D.
02-17-2008 06:48:18
 Re: Steel Prices in reply to Sam from WA, 02-16-2008 22:29:46
Hi SAM : I Too have an Old house like, That I will eventually have to do something , Only way I know is Pull all You can Out easily, and then take the Walls down (As much as need be) where You can see the Wiring entering/Leaving??Larry KF4LKU
sjh
02-17-2008 05:54:08
Best way is with a sharp knife. Burning it can make it brittle(hard to pick up) or melt it. Some yards pay less for it burnt as well.
awhtx
02-17-2008 01:43:13
When you burn the barn throw the wiring on the fire and it will burn the insulation off. Easiest way I know to do it.
WantACaseLASomeday
02-16-2008 20:36:18
 Re: Steel Prices in reply to 6U684, 02-16-2008 19:52:04
That's a huge problem now in Kansas - several athletic fields have been stripped of copper lighting wire to the tune of about $10,000 per field. They are even stripping the copper piping out of houses under construction. It is all a cycle though - when I was a rookie cop in the 70s they were after aluminum and we arrested two morons for ripping the siding off the backs of several houses in the daylight. They were thinking no one would notice if they just did the backs while people were at work.
