Tractor Talk Discussion Forum
1206 with TA elimintor kit - how hard to put TA back?
Dan Mahoney
02-19-2008 08:09:53
Does anyone know how hard, expensive it would be to take a 1206 with the TA eliminator kit and put the TA back into the tractor? Is this a difficult process?
ejr-IA
02-19-2008 17:21:42
 Re: 1206 with TA elimintor kit - how hard to put TA back? in reply to Dan Mahoney, 02-19-2008 08:09:53
I think also you will have to get a different MCV that will supply oil to the TA.
Kevin Meier
02-20-2008 14:11:23
 Re: 1206 with TA elimintor kit - how hard to put TA back? in reply to ejr-IA, 02-19-2008 17:21:42
that also depends on the elimination kit that was put in the tractor too ejr. The kit that I sell has pipe plugs to plug off the oil tubes to the t/a so the mcv doesn"t get messed with.
Kevin Meier
02-19-2008 13:48:26
It"s just a matter of splitting the tractor and putting the t/a in. As long as you"ve done that before there should be no problem. Depending on the kit you may need to remove the bushing from the pto also.
