Tractor Talk Discussion Forum
54 allis chamlers wd45 gas
rmh45
02-20-2008 09:35:51
hi, guys, need some help with a problem with water in the oil on a tractor i am thinking of buying.. what are the odds its just a head gasket, versus a cracked block. i have the capability of fixing either, but i think the cost of a different block would make the tractor to costly. would appreciate any comments on your experiences.
Dick L
02-20-2008 10:29:08
 Re: 54 allis chamlers wd45 gas in reply to rmh45, 02-20-2008 09:35:51
If it was from over heating and not setting outside where rain could get in, and it was a head gasket you would most likely have a miss if it is still running. If it is running and not missing my guess would be a freeze plug in the top of the head. They will tend to get holes in them in time without being overheated. If I were checking I would take the valve cover and check there first with a Little pressure in the radiator. If the leak was not there would remove the pan, wipe everything dry and with a little pressure on the radiator check for leaks from around the bottom of the sleeves. I would do that before removing the head. (if it is not a running tractor)
Dick L
02-20-2008 10:38:47
 NO in reply to Dick L, 02-20-2008 10:29:08
(if the tractor is running)
Glenn F.
02-20-2008 09:54:42
We need more information. THe following random questions/thoughts quickly come to mind:
Does it run? If so, look for evidence of compression in radiator while it's running.
Take a compression test.
ANY external cracks in engine block?
Is there anti-freeze in the oil, or is it possibly just rain water?
History. When was it last operated? Was it working properly then?
Do you know/trust the seller?
I wouldn't think a used block would bt too costly if you shop around.
Glenn F.
rmh45
02-20-2008 09:57:54
 Re: 54 allis chamlers wd45 gas in reply to Glenn F., 02-20-2008 09:54:42
ok, thanks for the comments, i don't know the seller, i have not had a chance to do any diagnoistic work, just kind of wanted to know odds,, it was running last summer, and he said it should start. will change oil before we load it if i continue with the purchase.
Nebraska Cowman
02-20-2008 10:00:46
 Re: 54 allis chamlers wd45 gas in reply to rmh45, 02-20-2008 09:57:54
Well slow down just a little. $1600 is a lot of money for a WD that needs work.
rmh45
02-20-2008 10:05:39
 Re: 54 allis chamlers wd45 gas in reply to Nebraska Cowman, 02-20-2008 10:00:46
thats kind of what i thought, but i have not shopped for a wd45 before.. anyway keep in mind the loader and the blade. i guess tires are ok, wide front. what would everyone think a fair price is given the information that we have.?
Glenn F.
02-20-2008 10:05:37
Yup!
Glenn F.
02-20-2008 09:56:25
Oops...I didn't read the entire thread before posting my response. Most of my points were already made.
Glenn
Nebraska Cowman
02-20-2008 09:52:44
Or how much water is in it. Have you taken the oil pan drain plug loose? Is it antifreeze or clear water? Could just be condensation?
rmh45
02-20-2008 09:54:01
 Re: 54 allis chamlers wd45 gas in reply to Nebraska Cowman, 02-20-2008 09:52:44
the oil is milky, have not drained the pan to see how much water is in it.. still dealing by internet.
Gary in da UP
02-20-2008 09:52:00
Plan for the worst, hope for the best. May be the O rings not sealing the sleeves. Plan on an overhaul.
rmh45
02-20-2008 09:55:33
 Re: 54 allis chamlers wd45 gas in reply to Gary in da UP, 02-20-2008 09:52:00
ok, he said he overheated it last summer and replaced the themostat and water pump.
duck1
02-20-2008 09:47:38
What does the owner say it is? i would explain how you see the situation and see if a reasonable price can't be reached.
rmh45
02-20-2008 09:52:36
 Re: 54 allis chamlers wd45 gas in reply to duck1, 02-20-2008 09:47:38
he thinks it is a head gasket, but he is just guessing like the rest of us.. he is not experienced in the tractor repair either. he is asking 1600.00 but it has a loader and a rear blade too.
El Toro
02-20-2008 10:19:05
 Re: 54 allis chamlers wd45 gas in reply to rmh45, 02-20-2008 09:52:36
If he overheated the engine it may have a cracked head. Check for bubbles in the radiator when engine is at an idle. I would do a lot checking
before deciding. He's too high in price. Hal
