Tractor Talk Discussion Forum
JD MODEL 60
PAINTHORSE1
02-20-2008 12:18:28
JUST BOUGHT A JD MODEL 60 AND AM NOT SURE WHAT TRANSMISSION OIL WEIGHT SHOULD BE .
ANY HELP WOULD BE GREATLY APPRECIATED
greygoat
02-21-2008 08:04:50
 Re: JD MODEL 60 in reply to PAINTHORSE1, 02-20-2008 12:18:28
Does it stall, at 20 below when you release the
clutch, with 140 weight?
buickanddeere
02-20-2008 23:53:02
1-800-522-7448. There is much more to know about that tractor's care and operation. A copper friendly GL-4 Marine gear lube is the safest oil to use in old machinery. Don't make a mistake and pour gear lube into the pto. The gear lube will ruin the clutch plates.
MPK
02-20-2008 19:42:44
In Mn we always used 90 wt so now it would be 80/90.
1 Dollar
02-20-2008 19:38:59
I used GL-1 140 wt. in my A. Happy with it so far. Got it from my local oil fuel delivery/ lubricant dealer.
This was the brand:
Pitalplace
02-20-2008 15:22:05
 Re: JD MODEL 60 in reply to T_Bone, 02-20-2008 12:18:28
I like the GL-1 140 the best helps cut down on gear noise. :D
in-too-deep
02-20-2008 15:14:04
A JD B calls for GL-1 gear oil, not GL-5. I'd 'spect it's the same for a 60.
Don c
02-20-2008 14:38:45
Find a dealer or someone that can get you some straight 140 w/t as the bronze bushing that are used in them doesn't like multi weight oil.
Allan In NE
02-20-2008 13:23:50
Aren't they just a sweet ol' tractor? The 60 and 70 were always my favorites.
Is yours late enough to have power steering?
Allan
steveormary
02-20-2008 16:01:03
 Re: JD MODEL 60 in reply to Allan In NE, 02-20-2008 13:23:50
Ya Allan,a 620 was on my list along with a Ford 7710 and the I found a 706 ger priced right.
steveormary
630man
02-20-2008 12:41:53
I used 80/90 weight oil in my 60 transmission
PAINTHORSE1
02-20-2008 13:23:53
 Re: JD MODEL 60 in reply to 630man, 02-20-2008 12:41:53
THANK YOU APPRECIATE IT.
