Tractor Talk Discussion Forum
O/T: '04 Trailblazer Heater Fan
MeAnthony
02-21-2008 03:03:48
Does not work on speeds 1-3, but does work on 4 and 5. Would this be a switch problem? Or is there a seperate circuit board that controls the heater fan?
Thanks for your opinion/suggestions
Anthony N.
Maark
02-21-2008 13:26:51
 Re: O/T: '04 Trailblazer Heater Fan in reply to MeAnthony, 02-21-2008 03:03:48
You will need to stand on your head to see and replace it.
Maark
02-21-2008 13:25:29
There is a resistor located in the bottom of the heater box. It is located in the right side of the passenger compartment, close to where your left foot would be. The plug-in sticks down. Costs about $28.00
glennster
02-21-2008 06:31:32
pull the plug out of the blower motor and see if its melted, not an uncommon problem,. gm has a service repair kit with a heavier plug and wires to update it. the resistor is located right nto the heater blower motor. under glove box on passenger side.
PeterT
02-21-2008 04:20:46
sounds like a resistor to me. not sure where it is located on that car.
