Tractor Talk Discussion Forum
OT - brake controller
time2plow
02-24-2008 07:56:52
I recently purchased a 2007 GMC half ton pick up.
I need to hook up a brake controller for my car trailer.
The owners manual says that there is wires next to the data port that are "butt cut" and to hook the controller to them. I have crawled all under the dash and have found nothing "butt cut". Any pointers would be greatly appreciated. thanks
Ryne
02-24-2008 16:30:44
 Re: OT - brake controller in reply to time2plow, 02-24-2008 07:56:52
My Mom had the same problem with her 07 Tahoe I went over and put in a controller for her after I found the wires which i believe there is four of them with pieces of black tape over the ends of them so they dont actually look butt cut because of the tape but they are underneath. But when i hooked up to the trailer to test it and it didnt work because the wires arent connected under the hood and have to be hooked up by a dealer so when took it to the local GM dealer and they connected to the main box under the hood.
Genos
02-24-2008 10:30:17
My 07 Chevy Came With A Harness For Brake Controller, I Would Look In glove Box Or Door Compartment. Thats Part Of The Towing Package.
Goose
02-24-2008 10:19:01
Unless you know positively that what you are doing is right, I'd go to a GM dealer or trailer shop.
I hooked up trailer lights on a Ford once, and they worked fine--as long as the trailer was hooked up. When the trailer was unplugged, the lights were all messed up on the pickup. Then I found out if you didn't use the Ford factory harness, you were basically screwed.
gene bender
02-24-2008 09:15:07
Have you thought about driving to the dealer and asking the service manager where it hooks. Thats what i did sure worked out fine.
jose bagge
02-24-2008 08:33:45
My chevy came with a wiring harness in the glovebox that plugged into a port on the fusebox under the dash that allowed for brake controller installation- it also included a large fuse that went into the fuse box under the hood that energized the trailer lights and put them all on seperate fuses than the truck lights. The wires on this accessory harness were "butt-cut"- look in the door pockets, glove box, etc for the harness. It also had a round-to-flat trailer plug adaptor taped to it. In the absence of the harness, a trailer shop or even TSC can hook you up with the right harness- I'd go that route rather than cut into anything.
