Tractor Talk Discussion Forum
grain drill
Mac / Wi
02-25-2008 08:36:16
I am going to look at 2 grain drills today. The advertisement did not include the make and model but one is a 3pt and the other is a 10ft trailer type. The advertisement also had the phrase"no grass". I am wondering if you could tell me what to watch for as I look at these and what the phrase, no grass means. Any help would be appreciated. Thanks in advance for you comments.
JMS/.MN
02-25-2008 08:51:33
 Re: grain drill in reply to Mac / Wi, 02-25-2008 08:36:16
"no grass" means it does not have an attached grass seeder, which is designed to seed small grass seed, while the main box is designed primarily for grain seed. Some larger grass seeds need to be run through the bigger box, since the flutes (which meter the seed) on the grass seeder are too small. What to check? Clean inside and out indicates proper care. No old seed in the box, missing tubes between flutes and disc openers, wobbly openers need adjusting or replacing. Rate adjusting levers should slide.
Bob
02-25-2008 08:45:31
I would ASSUME it meeans the drill is lacking "grass seeder boxes", which are separate of the main drill hopper, and have their own metering feeds, made for TINY seeds, such as grass.
