Tractor Talk Discussion Forum
400 chevy engine weight
caleb in pa
02-26-2008 14:05:55
does any body know roughly what 400 chevy engine weighs? what does block wiegh? What does complete engine weigh?
jdemaris
02-26-2008 15:26:41
 Re: 400 chevy engine weight in reply to caleb in pa, 02-26-2008 14:05:55
A 400 with cast-iron heads weighs around 575 lbs.
Here are few specs:
Chevy Vega L4 285
Chevy II 153 L4 350
Chevy L6 194-250 440
Chevy L6 216/235 630 (2)
Chevy L6 216/235 615 (88) "265 V8 was 40# lighter than 235"
Chevy V6-90 229, 4.3 425
Chevy V6-60 2.8, 3.1 350 (2)
Chevy small block V8 535 (1) ('59 Corvette 283 w/alum. intake)
Chevy LT-5 DOHC 5.7 600 (122)
Chevy L98 5.7 V8 600 (122)
Chevy V8 348/409 620 (1)
Chevy big block V8 685 Mark IV
Chevy big block V8 --- Mark V
Chevy 454 675 (10)
Chevy 427 ZL-1 550 (35) all-aluminum, "20# lighter than SB"
Ford flathead V8 525 (124) 1932 model, integral b'hsg, iron heads
Ford flathead V8 569 (1) ('53 239 CID)
Ford Cosworth DFV 353 (2) (racing engine, DOHC, 3.0L)
Ford 255 Windsor 468 (4)
Ford 289/302 V8 460 (168) (late 5.0s are a bit lighter)
Ford 221-302W 460 (48)
Ford Indy 255 pushrod 360 (120) all aluminum, 1963
Ford Indy 255 DOHC 400 (120) 1964, later known as Foyt Coyote V8
Ford 5.0 V8 450 (109)
Ford 5.0 V8 411 (171) 89 Mustang 5.0 GT (dry) inc: manifold, carb(?), headers and alternator. Not inc: starter, smog pump, power steering pump, AC compressor, flywheel Ford BOSS 302 500 (48)
Ford 351 Cleveland 550 (48) (includes BOSS and Australian 302-C)
Ford 351 Windsor 510
Ford 351 Windsor 525 (48) (168)
Ford 351M-400 575 (48)
Ford Y block V8 625 (272-312 CID)
Ford FE big block 650 (332-428 CID)
Ford FE big block 670 (1) ('59 352 CID)
Ford FE 625 (48)
Ford 427 SOHC 680 (48)
Ford 429/460 V8 640
Ford 429-460 720 (48)
Ford 460 V8 720 (10)
Ford BOSS 429 680 (iron block, aluminum heads)
Ford BOSS 429 635 (48)
Ford 4.6 SOHC 530 (93) iron block, aluminum heads
Ford 4.6 SOHC 473 (72)
Ford 4.6 SOHC 600 (168) (Mustang)
Ford 4.6 DOHC 464 (72) "9 pounds lighter than SOHC"
Ford 4.6 DOHC 437 (77) without accessories
Ford 4.6 DOHC 521 (94) aluminum block and heads
Ford 4.6 DOHC 576 (168) (Mustang)
Ford Triton V10 635 (128) "dressed"
Chrysler 2.2 L4 216 (6) (bare motor)
Chrysler 413 wedge 640 (1) ('59 300-E)
Chrysler 331 Hemi 745 (5) 1955
Chrysler M4 tank engine 5,244 (87) 30 cyl, 5 banks of 6, flathead, WWII
Chrysler 1955 V8 691 (99) Spitfire, 'polyspheric', 300 ci 188 hp
Chrysler 1955 Hemi 729 (99) Firepower 331.1 ci, 250hp, 1x4v
Chrysler 1955 300 Hemi 735 (99) C-300, 331.1 ci, 300hp, 2x4v
Chrysler Patriot 186 (110) gas turbine (part of hybrid EV)
Chrysler CR2A turbine 410 (111) 1964 Turbine Car, 130hp SAE net
Mark - IN.
02-26-2008 15:42:20
 Re: 400 chevy engine weight in reply to jdemaris, 02-26-2008 15:26:41
That surprises me about the Mark I 348/409. As I recall, the whole idea for what ultimately became the trimmed down Mark IV big blocks was to cut the weight down from the Mark I so could have big block power in Corvettes to go up against big Fords and Chryslers without messing up the 55/45 front to rear weight ratios for handling too much. The Mark IV changed it to 60/40, as I recall, and the Mark I was going to pretty much not make it a handling car at all because of its weight.
Mark - IN.
02-26-2008 15:22:32
 Try this in reply to caleb in pa, 02-26-2008 14:05:55
Ever hear of Smokey Yunick? He was Mr. Smallblock. Do it right, or don't do it at all. If you want good, correct answers, start with Smokey. Had several books out, this is one.
SteveKY
02-26-2008 15:13:54
Small block 494lbs big block 545lbs complete engine no accessories.Steve
