Tractor Talk Discussion Forum
OK Now that I have asked the first question..hers the 2nd
Raleigh
02-27-2008 17:15:30
OK here is what I am trying to figure out ....It seems from the first question that my cylinder and packing in my Rockshaft is OK.
So my problem MUST be in the flow control valve.
Here is whats happening when I lower my implement to a certain level that I want to work at (BushHog in this instance) it does not stay there. It will, after about 10 minutes of work, sag all the way to the ground. Yes I have the Adjustment on "D" on the selector.
What I am failing to understand is how the rock shaft operates in that when I set my lever at a certain position how does the rockshaft know to go in that position? Where is the closed loop to tell where to stop or move to?
Tx Jim
02-28-2008 03:21:13
 Re: OK Now that I have asked the first question..hers the... in reply to farmer101IL, 02-27-2008 17:15:30
Raleigh when rockshaft settles all the way down while engine is running does your control lever on dash settle also or does it stay where you put i? Jim
Heat Houser
02-27-2008 18:48:20
 Re: OK Now that I have asked the first question..hers the... in reply to Raleigh, 02-27-2008 17:15:30
If the tractor is running, the hitch should automatically re-adjust upward for any settling that may have occurred.
I assume a 4020 JD. There is a cam on the rockshaft and on the cam rides a follower that is connected to the draft sensing linkage. A roller in the rockshaft valve's linkage rides on the follower. If you are set on "D" the draft sensing linkage does not have any effect on the rockshaft valve, only the cam's position can affect the valve.
The valve consists of two balls and seats. One is for raise, the other for lower. The rockshaft valve's roller is pushed back or allowed to move forward due to the cam action as the three point goes up or goes down. Via the linkage that is connected to the roller, the corrisponding ball is pushed off it's seat and allows oil in if it needs to raise, or out if it needs to lower. The cam rotates as it is raised/lowered and when it gets high or low enough, the ball re-seats and flow is stopped. The hitch then maintains that position until it leaks down slightly or until you move the three point lever. The correct ball is then pushed open and the hitch reacts again.
Raleigh
02-28-2008 07:23:32
 Re: OK Now that I have asked the first question..hers the... in reply to Heat Houser, 02-27-2008 18:48:20
MAN!!! thanks a WHOLE Bunch this is the BEST answer I have had to this question SO FAR!!!
Thank you!! Thank you!! thank you!!!
Hey could anybody else add to this answer he gave this makes mor senes to me now!!
rusty wheel
02-27-2008 17:36:27
If your impliment is drifting down, it could be that the oil is bypassing the piston seal in the cylinder..... ..... ..rw
