Tractor Talk Discussion Forum
farmall sheet metal
jim jackson
02-29-2008 05:23:06
anyone know if the farmall cub and b fenders are interchangable, how bout the A and b hoods,..also from my earlier post, still looking for the serial # on seat frame, was this a tag or a stamp into meatal part on 1941 BN,..
gots-2-go
02-29-2008 06:08:46
 Re: farmall sheet metal in reply to jim jackson, 02-29-2008 05:23:06
As Gene said the fenders from a cub will not fit, but the hood from a A will work on a B.
As for the serial number most I have seen did have a tag attached to the inside of the seat frame on the left side (next to the transmission).
Check the area around the #1 sparkplug, there should be a flat area about 1/2" high by 3" long that has the serial number stamped in it.
If the motor is orginal it should be the same as the tag on the seat frame or close. You may need to scrape the paint or dirt/grease off of it to be able to read it.
gene bender
02-29-2008 05:26:06
CUB fedners wont fit the A or B. The hoods for A and B are the same New ones arent that pricey.
