Tractor Talk Discussion Forum
STARTER FOR A BF AVERY MODEL A
TIM HIBEN
03-02-2008 06:40:43
DOES ANYONE KNOW IF THERE IS A STARTER THAT WILL FIT A BF AVERY MODEL A BESIDES THE ORIGINAL? IS THERE A SUBSTITUTE FOR THIS MODEL?THANKS TIM
John N Mi
03-02-2008 16:04:52
 Re: STARTER FOR A BF AVERY MODEL A in reply to TIM HIBEN, 03-02-2008 06:40:43
NO The Oliver OC 3 uses the same starter. Anything with a Hercules I X B engine uses this starter. If you have a good frame a auto electric shop should be able to replace the coils if they are bad. The rotor will be harder to do. Some air compressors used this same engine but I don't know which ones. And no I will not give up my spare starter.
John
TIM HIBEN
03-02-2008 17:27:23
 Re: STARTER FOR A BF AVERY MODEL A in reply to John N Mi, 03-02-2008 16:04:52
HI JOHN, THANKS FOR THE REPLY ON THE STARTER , I WILL CHECK WITH THE LOCAL TRACTOR SALVAGE AND SEE IF THEY WOULD HAVE ONE ...THANKS TIM
