Tractor Talk Discussion Forum
Detroit diesel retrofit
steve21757
03-02-2008 07:20:36
I am in the process of installing a detroit 3-71 engine in a Case 500 tractor.We are having trouble figuring out how to mate the tractor trans drive components i.e clutch,pressure plate assy, to the input shafts of the trans.Does anyone have any plans or know how to do this as it was done many times to repower Case tractors.Your help is very appreciated. STEVE21757.
buickanddeere
03-02-2008 08:01:16
 Re: Detroit diesel retrofit in reply to steve21757, 03-02-2008 07:20:36
Link
That 3-71 will start & run much better with "N" series sleeves/pistons. And "C" series injectors. Don't grind the valves or seats. It sinks them and lowers compression.Install new. I think there is a valve spring and cam follower spring upgrade on the 71 series too.
Notyet
03-02-2008 08:13:06
 Re: Detroit diesel retrofit in reply to buickanddeere, 03-02-2008 08:01:16
Buickanddeere....that should solve the problem about the refit of the detroit to the 500 case
