Tractor Talk Discussion Forum
OT Dodge Pick-up
Ford 312
03-05-2008 12:29:44
In an earlier post I wrote about speedometer not working right on a 1994 Dodge Ram 1500. We changed the sensor on the transfer case but speedometer still only works some of the time. Transmission shifts O.K. including into Over Drive. Any suggestions? Thanks in advance.
Jim J
03-05-2008 14:51:13
 Re: OT Dodge Pick-up in reply to Ford 312, 03-05-2008 12:29:44
Did you pull the complete assembly out of the transfer case or did you just replace the sensor? The assembly is on an eccentric and if is like my Dodge, when I had the transfer case rebuilt the guy didn't put the assembly in correct and the gears didn't mesh and the speedometer didn't work.
Janicholson
03-05-2008 14:40:55
Intermittent connections are tough to find. Start at the sensor, and follow the wires./connectors there is corrssion, or a break somewhere. The supply voltage could also be intermittant. Use a diagram to assist. JimN
