Tractor Talk Discussion Forum
OT IHI ESKAVATOR LOOSING OIL
city farmer
03-05-2008 13:56:14
I HAVE A IHI MED SIZE TRACK HOE THAT IS RUNNING OUT OF OIL NEARLY EVERY DAY WHEN USED DOES NOT SMOKE BUT SEEMS TO BE BLOWING THE OIL OUT OF THE FILL TUBE AND OUT OF A HOSE THAT STICKS OUT THE BOTTOM DOES THIS MEAN TI NEEDS A REBUILD OR IS THERE SOMTHING ELSE I SHOULD BE LOOKING AT THIS IS A DESIL ENGINE THANKS MARK
Leland
03-05-2008 16:38:22
 Re: OT IHI ESKAVATOR LOOSING OIL in reply to city farmer, 03-05-2008 13:56:14
or a piston with a hole burnt in also
Michael Soldan
03-05-2008 16:36:36
yep...PCV valve is plugged or the line that goes intoit..blow oil out of an engine real quick...
Brian W
03-05-2008 14:38:18
Check and make sure the hose coming from the valve cover is not kinked or plugged. How many hours are on the machine?
