Tractor Talk Discussion Forum
JD 450C Loader runs but stalls out
Robert Merrill
03-06-2008 05:20:00
I have a JD 450c loader that will start up fine but after a few minutes of running it loses rpm and eventually dies. I replaced the fuel filter but that did not help. Any ideas. Maybe the fuel pump is not working? Could the turbo be stuck but it runs OK for a few minutes. Any ideas?
2x4
03-06-2008 15:46:29
 Re: JD 450C Loader runs but stalls out in reply to Robert Merrill, 03-06-2008 05:20:00
My 450 did the same thing. It had black gunk in the fuel tank, lines from tank to fuel pump & in pump. An algae grows between the water & fuel in the tank. This gunk clogs shut-off valve & lines. Drain & clean tank, blow out lines, clear orfices if this is the case & it will run like a top.
CCer
03-06-2008 13:32:18
A blockage in the return line system will cause your problem also. Outlet fitting on the Inj. pump may plug if pump is failing.
jdemaris
03-06-2008 05:48:56
If fuel is flowing properly to the injection pump, you probably have a failed governor weight-retainer ring inside the injection pump. It's can be a four hour job to fix including removing the pump, fixing the pump, and reinstalling - if you find the right person to do it. Otherwise - it can cost you over a $1000.
If fuel is not getting to the pump, or has air in it, check the obvious - e.g. the fuel valve at the tank bottom, fuel transfer pump, etc.
