Tractor Talk Discussion Forum
Wind turbine overspeed failure
buickanddeere
03-06-2008 09:18:49
Link
At about 5 seconds there may have been a total brake failure either from fade or due to the generator/gearbox centrifugal explosion.15 seconds time, one of the blade tips at about the 3 o'clock position goes supersonic and shatters. The hub/nacelle now unbalanced lets another blade impact and crease the tower causing structural collapse. The three techs probably made it down the tower and 1/2 a mile away in Olympic record time. Early reports are of bearing failure in the hub which prevented feathering the blades. Insufficient maintenance and cost cutting is the likely cause. Vestas is going to get blamed anyways, their price and demand will drop.
mj
03-07-2008 09:03:34
 Re: Wind turbine overspeed failure in reply to MN Bob, 03-06-2008 09:18:49
I believe it was Admiral Byrd that placed a Hobbs 3-blade wind generator down at the south pole and left it there. Some 60 years later another expedition re-visited the site and there was the old Hobbs ..... still turning with the wind! :shock: I realize that these modern ones are much larger and made of the latest materials but ..... SIXTY YEARS!? As I recall, Mr. Hobbs had dozens of patents relating to windmills and his company was renowned for making the 'Cadillac' of wind machines at the time.
mj
03-07-2008 08:54:04
 Re: Wind turbine overspeed failure in reply to Rod in Smiths Falls,, 03-06-2008 09:18:49
Kentb of SWMO said: (quoted from post at 08:49:26 03/07/08) I can not get to the video. How do you make the youturbe arress a link?. I type in the address bat but youtube rir not accept. I tried to highlight but could not get anywhere. HELP Please.
Kent
Here ya go:
Link
Kentb of SWMO
03-07-2008 06:49:26
 Re: Wind turbine overspeed failure in reply to buickanddeere, 03-06-2008 09:18:49
Kent
buickanddeere
03-07-2008 08:23:22
 Re: Wind turbine overspeed failure in reply to Kentb of SWMO, 03-07-2008 06:49:26
Just sign onto Utube and search for wind turbine accident.
Jerry/MT
03-06-2008 12:06:16
Looks like the support tower was made of composite material.
buickanddeere
03-06-2008 19:40:28
 Re: Wind turbine overspeed failure in reply to Jerry/MT, 03-06-2008 12:06:16
Steel tower. Blades were composite.
Dan-IA
03-06-2008 11:43:21
When I was in high school Dad built his own wind generators. Then in some big storm in mid-winter they went overspeed and the blades flew apart. My theory is ice on the blades took 'em out of balance, they should have had no trouble handling the speed.
It's just about the sick feeling you get right after you wreck a car, get out, and inspect the damage. A lot like that anyway.
Dan-IA
03-06-2008 11:43:14
cj3b_jeep
03-06-2008 11:34:25
There's a half a million bucks down the tube!
bradk
03-06-2008 10:03:26
That sucker was movin'!!
Good vid!!
MN Rick
03-06-2008 09:35:11
one of the more interesting videos I've seen. Simply amazing
