Tractor Talk Discussion Forum
Hey Dick L!!
Allan In NE
03-06-2008 09:23:44
Would be interesting to hear your thoughts on the practice of turning off the fuel at the sediment bowl after shutdown?
Allan
wdTom
03-06-2008 17:31:10
 Re: Hey Dick L!! in reply to Allan In NE, 03-06-2008 09:23:44
Easy to turn off if you put a ball valve in the fuel line, the quarter turn type, 1/8 or 1/4 npt brass ball valves with stainless ball are only a few dollars.
ScottyHOMEy
03-06-2008 12:02:50
I vote for shuttin' off any gravity feed gas nay time you're not runnin'. Dick L mentioned hauling, and it makes me think that the vacuum over the top of an exhaust pipe movin' at fifty miles an hour would draw gas through an open intake valve and have ya seriously flooded by the time you get very far.
My question in that regards is whether or not to run the bowl dry. I tend not to. Strikes me gaskets and stuff tend to dry up, crack from shrinkage, etc., if left dry too long.
neblinc
03-06-2008 10:28:22
At $3.00+ a gallon, it's a no brainer for me.
Randy
coloken
03-06-2008 10:13:44
Two things I have always done. Befor I start a tractor, I pull the dip stick and check the oil When ever I shut off a tractor, I shut off the gas at the sediment bowl. Does not apply to later tractors with low down tanks and fuel pumps.
Dick L
03-06-2008 10:06:49
I do on some of my tractors and always did on my pulling tractors after I loaded them. The reason was to keep the gas in the tank rather than on the trailer deck or on the ground. It didn't happen every time but every now and then the float valve seat would unseat and I would loose the gas. I turn them off over winter on 10 or 11 of them.
CWL
03-06-2008 09:28:16
Now on that one my vote is every time I shut the tractor down for the day.
