Tractor Talk Discussion Forum
OT - replacing timing chain and sprockets
Dan-IA
03-07-2008 13:06:44
I tore down the car with a funny noise. Not knowing what I was in for, I planned to pull the whole engine out. But somewhere along the way Dad said "check the timing chain." So we pulled that cover.
Well, after the chain and sprockets were out, I did a chain-slop test on the camshaft sprocket. That video shows the old chain first, then the new one.
Is that enough to make my noise, or should I still plan to pull the head? I'm thinking I might put it all back and try it first.
olddog
03-08-2008 04:16:07
 Re: OT - replacing timing chain and sprockets in reply to Dan-IA, 03-07-2008 13:06:44
I've driven chevys with chains so loose they wore a hole in the cover, that never rattled and ran smoothly. Only warning was oil leakage.
36 coupe
03-08-2008 03:34:07
A worn timing chain will jump timing.Never heard a noisy one.Timing gears will make noise.Might as well put in a new one if you have it apart.If it jumps time on the road the tow will coat way more than a new chain and gear.
bradk
03-07-2008 19:17:44
So how was the auto tentioner as I mentioned in orig post?
Is there material on shoe and is spring intact?
Jim in Ma.
03-07-2008 17:46:22
Yep!! I have seen that on small block chevys to.
El Toro
03-07-2008 15:00:03
Timing gears will make a noise. My late father-in-law had a 1950 Ford with about 50k miles and it started making a noise that sounded like a loose rod. They told him at the Ford garage it was the timing gear so he and I instaleed a new gear. That cured the problem. Hal
e
03-07-2008 13:30:56
If the timing chain was wore out, it wouldn't "all of a sudden" start making noise.
Does you engine sound like this?
Dan-IA
03-07-2008 15:22:22
 Re: OT - replacing timing chain and sprockets in reply to e, 03-07-2008 13:30:56
Sounded more like this--but didn't usually do it stone cold - took a couple minutes to start.
