Tractor Talk Discussion Forum
Perkins 540 water pump.
Bill from Scotl
03-08-2008 08:58:00
Hi Guys
Has anybody managed to dismantle a Perkins 540 V8 water pump without destroying it? It is the one with the two shafts. The shaft with the impeller needs to be pushed out of the larger shaft with the bearings on it, Mine seem almost impossible to shift. Any ideas on how I can do it? I have access to a hydolic press. Dont want to break it and I am not sure that the body of the pump can withstand the force from the press.
Thanks
Bill
Kevin Meier
03-09-2008 12:17:19
 Re: Perkins 540 water pump. in reply to Bill from Scotland, 03-08-2008 08:58:00
The water pump that I believe you are working on should have a casting number of #37711030? It only has one shaft in the pump though. You should be able to take out the snap ring and press the shaft out the top end of the pump. There should be 2 pilot bearings that have a steel tube for a spacer in the middle. The bearings press off with the pulley end of the shaft pointin up.
nhboyd
03-08-2008 17:03:29
Do you have the pulley off. there is a snapring in the housing that holds the bearing in.
