Tractor Talk Discussion Forum
What can you tell me about
old
03-08-2008 12:14:54
A Kabota D7100 tractor. Friend just traded for it and he wants me to find out as much as I can for him. I know its a 3 cylinder diesel, 4 wheel drive, has loader and 3 point. So how many HP is it how big a brush hog will it handle?? ETC. etc.
paul
03-08-2008 14:15:46
 Re: What can you tell me about in reply to old, 03-08-2008 12:14:54
Ran my brother in law's tired 7100. 16 hp, he uses a lot of 4 foot equipment behind it, mower, tiller, etc. Pulls a NH 33 side rake but you sit too close tot he dust, runs a 30' 6inch grain auger, will pull an old JD wooden live-bottom manure spreader with cobs in it, and runs a post hole digger pretty good. Runs a Troybuilt chipper fine, if you have enough patience to bother using one of those.
About all I know.
--->Paul
1 Dollar Joey H.
03-08-2008 13:20:21
If you're talking about a B7100, like the other guy mentioned, I can help there.
I run my neighbors B7200 with a 4-foot finish mower in the summer, but in taller pasture grass. It handles it, but go pretty slow and that is where the hydro is nice. It pulls through it all suprisingly well. You can coax a hint of smoke out of it if you get it loaded JUST right :)
It is a 4WD with turf tires. Cold starts are iffy, even with glowplugs. I can mow the 2-acre yard 5-6 times on five gallons of fuel. Front end weight is necessaty with anything on the 3-point.
Hope this helps.
Amarillo Doug
03-08-2008 13:08:17
Old,I checked my latest tractor data charts and they don't list a D7100 Kubota.However theydo show a B7100.It is rated at16 hp engine and 11hp PTO.
old
03-08-2008 14:34:10
 Re: What can you tell me about in reply to Amarillo Doug, 03-08-2008 13:08:17
Might be a B instead of the D. I looked at it but that was about all. I know the 7100 is correct. Seemed to run ok but didn't do more then here it run because it was on a trailer.
