Tractor Talk Discussion Forum
Dry metal chopsaws
Oldoaky-2
03-11-2008 07:00:49
What other kinds of "dry" metal chopsaws are there? The ones that are not abrasives. Milwaukee makes one that is fairly reasonable but I know there are others out there. Does Dewalt make one or some other industrial company?
Thanks for any input.
Zach from TX
03-11-2008 18:15:06
 Re: Dry metal chopsaws in reply to Oldoaky-2, 03-11-2008 07:00:49
We have a DeWalt that we are very satified with. It was pretty expensive, and the blades can be in the $100 area, but they last quite a while. There are no sparks, and the metal isn't red hot when you get done cutting, however it makes little cuttings that seem to fly right in your face.
John S-B
03-11-2008 13:57:03
I was going to get rid of my Craftsman radial arm saw since I got a DeWalt sliding miter saw, it hasn't been used for years. But I saw some nice carbide blades at a industial hardware store so I'm gonna make it my metal saw now. Can't remember the brand of the blades tho.
jokers
03-11-2008 10:22:07
I`ve got the Milwaukee version and it`s schweeeet!
Tim B from MA
03-11-2008 08:24:02
I have a Makita 12-inch chop saw made for their 12-inch carbide metal cutting blade.
I bought mine slightly used. It is certainly cleaner (smoke wise) and less smelly than abrasive blades. However, mine does not cut well through the flat side of steel (e.g., small pieces of sheet metal laying horizontally, or side of a square tube), though it works very well when cutting perpendicular through the steel (eg. angle iron with the peak up).
I'm not sure if this is a characteristic of these blades, or if mine was dulled before I bought it (myself, I have been careful to treat it nicely).
jokers
03-11-2008 10:25:01
 Re: Dry metal chopsaws in reply to Tim B from MA, 03-11-2008 08:24:02
Tim,
It does sound as if your blade might be slightly dull when compared to my experiences. Also remember that you want enough feed pressure to take chips so the blade doesn`t overheat on you, babying the cut will ruin the blade.
wyod
03-11-2008 08:07:03
few years back, Porter Cable had one w/carbide blade... nice saw, reasonably priced... not sure if it's still available tho...
eli fish
03-11-2008 07:39:42
Yes dewalt makes a metal blade chopsaw for cutting steel. They work well with carbide tipped metal blades.
