Tractor Talk Discussion Forum
no oil pressure
tom 88
03-12-2008 06:16:07
i have 8n it sat in barn 10 yrs. when i started it has no oil pressure oil new does pump on this run off of cam shaft?
pitch
03-12-2008 06:48:13
 Re: no oil pressure in reply to tom 88, 03-12-2008 06:16:07
Pump is on the #1 main bearing. There is a capscrew on the timing cover, inside will be a spring and ball bearing. Remove these and prime with some gear lube and try again. Losing prime is not uncommon in an N that has sat for a while
tom 88
03-13-2008 03:30:56
 Re: no oil pressure in reply to pitch, 03-12-2008 06:48:13
thank you good info. it worked
Janicholson
03-12-2008 06:44:59
Pump oil into the oil pressure gauge hole in the engine with a hand pump oil can. Use a piece of rubber hose to make a temporary connection to allow oil to enter the gallery. This will prime the system, and assure a chance for the pickup to suck new oil. (I would also put a squirt in each cylinder to lube the rings. JimN
El Toro
03-12-2008 06:17:51
Did you prime the pump in a clean container of engine oil? Hal
tom 88
03-13-2008 03:28:52
 Re: no oil pressure in reply to El Toro, 03-12-2008 06:17:51
yes i did and it worked thanks
