Tractor Talk Discussion Forum
O/T Dodge Ram Steering seal
Chris in SK
03-14-2008 21:44:25
My 99 4x4 Ram just started leaking PS fluid from the selector shaft seal. Up until tonight there was no trace of a leak. Will I get away with just replacing the lower seal and adjusting the preload, should i rebuild it or get a recon unit. I've changed lower seal sucessfully in similar steering gear boxes on other trucks but not on a Dodge. Interested to hear anyone's expirience with this steering box before I drag myself under it tomorrow. Thanks
Chris
david from mo
03-15-2008 22:39:42
 Re: O/T Dodge Ram Steering seal in reply to Chris in SK, 03-14-2008 21:44:25
PITMAN SHAFT/SEALS/BEARING
DISASSEMBLY
Clean exposed end of pitman shaft and housing with a wire brush. Remove preload adjuster nut Side Cover and Pitman Shaft Rotate the stub shaft with a 12 point socket from stop to stop and count the number of turns. Center the stub shaft by rotating it from the stop 1/2 of the total amount of turns. Remove side cover bolts and remove side cover, gasket and pitman shaft as an assembly Side Cover and Pitman Shaft NOTE: The pitman shaft will not clear the housing if it is not centered
Remove pitman shaft from the side cover. Remove dust seal from the housing with a seal pick Pitman Shaft Seals & Bearing CAUTION: Use care not to score the housing bore when prying out seals and washer.
Remove retaining ring with snap ring pliers Remove washer from the housing. Remove oil seal from the housing with a seal pick. Remove pitman shaft bearing from housing with a bearing driver and handle Needle Bearing Removal ASSEMBLY
Install pitman shaft bearing into housing with a bearing driver and handle. Coat the oil seal and washer with special grease supplied with the new seal. Install the oil seal with a driver and handle. Install backup washer. Install the retainer ring with snap ring pliers. Coat the dust seal with special grease supplied with the new seal. Install dust seal with a driver and handle. Install pitman shaft to side cover by screwing shaft in until it fully seats to side cover. Install preload adjuster nut. Do not tighten nut until after Over-Center Rotation Torque adjustment has been made. Install gasket to side cover and bend tabs around edges of side cover Side Cover and Pitman Shaft Install pitman shaft assembly and side cover to housing. Install side cover bolts and tighten to 60 N·m (44 ft. lbs.) Perform over-center rotation torque adjustment.
Chris in SK
03-16-2008 21:29:19
 Re: O/T Dodge Ram Steering seal in reply to david from mo, 03-15-2008 22:39:42
David, I removed the P/S box to do it on the bench. I took out the pitman arm shaft as you said. Fitting the seals was fairly simple, and has stopped the leak. Thanks for all your help. Chris
jdemaris
03-15-2008 06:48:22
I just put new seals in the power-steering box on my 92 Dodge W250. It was actually the same as all my GMs. Dual seals and a snap ring behind the pitman arm. Took less than an hour.
david from mo
03-15-2008 08:46:04
 Re: O/T Dodge Ram Steering seal in reply to jdemaris, 03-15-2008 06:48:22
Correct on old system .new has one seal must remove shaft to replace on 99 .chrysler master tech
Chris in SK
03-15-2008 11:37:45
 Re: O/T Dodge Ram Steering seal in reply to david from mo, 03-15-2008 08:46:04
David, can i remove the retaining ring, pressurize the box and force the old seal out without removing the sector shaft. Then fit the new seal?
Thanks
david from mo
03-15-2008 22:34:38
 Re: O/T Dodge Ram Steering seal in reply to Chris in SK, 03-15-2008 11:37:45
don't think it will work like the gm gear .think you must remove pitman arm the hard part, then remove top of gearbox ,pull shaft up and then remove seal. you could try the old gm way first before you remove the top / if it won't come out you have not lost anything.david
david from mo
03-14-2008 22:08:28
Must remove pitman arm .4 bolts on top. pull shaft out top. note postion of shaft to index. o remove bottle off rad . not bad job .lt will stop the leak david
