Tractor Talk Discussion Forum
fuel [for hillbillys rednecks and other folks like me]
ericlb
03-15-2008 12:18:33
ok with all the posts on fuel prices, i got a debate for you, if we were to "accidently" build a still, and it "accidently" made corn whiskey, if we added say a cup of 10wt oil to a gallon of this for lubrication would a gas engine tractor run on it and would it run well or lead to a early engine failure?
trucker40
03-17-2008 11:17:39
 Re: fuel [for hillbillys rednecks and other folks like me] in reply to ericlb, 03-15-2008 12:18:33
I read somewhere that you need to run it back through the still until you get it to 190 proof,then some kind of desicant to get rid of all the water.Then you have 200 proof alcohol.White lightning is only 100 or 120 proof.
rrlund
03-16-2008 09:31:40
Grannys sure made the Clampetts old truck go like 60!
Bus Driver
03-16-2008 04:23:52
In the distilling process for ethanol, the alcohol/water mixture boils off and the resulting mixture has too much water to be used for fuel. About 95% alcohol is the best that distillation can do. Removal of the water requires additional processing and/or chemical treatment.
ericlb
03-15-2008 19:16:49
man, i didnt know shine had gotten that high, my last gallon was gave to me as a bonus for some work i did,for a person, but that was quite awhile ago [ several years]so much for that idea, just thought id ask since i do have access to most of the stuff to build a still, but the sugar might be a real problem
Pitalplace
03-15-2008 17:24:57
 Re: fuel [for hillbillys rednecks and other folks like me] in reply to cj3b_jeep, 03-15-2008 12:18:33
Sell the shine and by gasoline. :P :P :twisted:
davediehl@hotmail.com
03-15-2008 16:37:54
You should bring back the steam powered car. Its cheaper.
thinking
03-15-2008 16:05:09
will oil mix with shine
hay
03-15-2008 13:15:16
my old late great grandpappy was running 'squeeze' in the truck and on the truck before anyone thought of alternative fuel. get low on gas and pull over and take a swig from the jug and pour the rest in the old chevy. mighty mighty pleasin', pappy's corn squeezin'.
Joe from MN.
03-15-2008 13:07:36
That's not a debate -- and Stupidity is Not a Handicap ....
joho
03-15-2008 13:07:22
Wow, man its around $60. a gallon here in our valley. We been gittin' ripped off!
2x4
03-15-2008 18:20:38
 Re: fuel [for hillbillys rednecks and other folks like me] in reply to joho, 03-15-2008 13:07:22
you're about right. Paid $55 for my last jug.
Pooh Bear
03-15-2008 13:06:17
Why do it 'accidently' when you can get a permit for it.
You can't produce it cheaper than gas UNLESS
you have a free supply of fermentables
AND a free supply of fuel to run the still.
If you can get sugar by the ton CHEAP
that will make the best fermentable.
Pooh Bear
ericlb
03-15-2008 12:19:44
forgot to add would it be cost efective to do it
bva
03-15-2008 12:48:46
 Re: fuel [for hillbillys rednecks and other folks like me] in reply to ericlb, 03-15-2008 12:19:44
Since we are assuming, lets just say that if you can produce corn whiskey to a very good drinkable spelled (sippin) stage then it is not cost effective to use it as fuel in that 20 dollar sippin will buy you 5 gallons of 4 dollar fuel. Since corn and fixins are goin up then sippin whiskey is probably near 30 dollars a gallon though. Good luck on your accidental endevours.
