Tractor Talk Discussion Forum
tractors that will fit a JD #10 side mount mower
rfb
03-15-2008 14:22:28
What JD model tractors will a JD #10 side mount mower fit on? Looking at a 2510 or 3010, will it fit on these?
jd-tom
03-15-2008 14:33:22
 Re: tractors that will fit a JD #10 side mount mower in reply to rfb, 03-15-2008 14:22:28
Depends on which mounts are with it. There is one set of mounts for mounting it on the later 2-cylinder tractors. This set had parts with it to drive the mower from the rear PTO. The other set of mounts are for the 3010-4010 series tractors and that one drives off the the mid PTO on those tractors.
rfb
03-15-2008 18:36:38
 Re: tractors that will fit a JD #10 side mount mower in reply to jd-tom, 03-15-2008 14:33:22
I have the serial # from the JD #10. would this identify what tractors it would fit?
jd-tom
03-15-2008 19:30:07
 Re: tractors that will fit a JD #10 side mount mower in reply to rfb, 03-15-2008 18:36:38
I don't think the serial # would tell which mounts are with it.
jd-tom
03-15-2008 14:38:18
I should have added to my first post that the ones driven off the mid PTO are 1000 rpm and the ones that are driven off the rear are generally 540 rpm (but those could be 1000 rpm also). If you already have one or have one spotted, you would do well to get a parts book for this mower so you can identify parts that are with it to determine which mounts it has.
